Page 8 of 42 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 415
Thread: Team MedBots
  1. #71
  2. #72
  3. #73
    Max's Avatar
    Member
    2 questions today,
    Would 2mm steel be ok for base and armour? It would be well supported.
    Also how do you full pressure flippers guys attach a pipe to your bottle, more specifically ones with a co2 nut type thread? I don't understand how you attach a pipe to the co2 nut.
  4. #74
  5. #75
    Max's Avatar
    Member
    Hi all,
    I've spent the 3 hours just discussing with my dt teacher how my flipper design it wrong rather than getting on building it
    But I do see his point, because the ram is mounted nearly horizontally the force going upwards should be almost zero (cosine of angle times force . if angle is 90 then times force by 0!)
    He suggested using a elbow shaped linkage which should mean most the force goes up but it has a lot more parts to go wrong and break and it makes the robot bigger and using the ram in reverse so a bit less force and one of the pivots has to move in a slot.
    Also he recons you only need 70mm movement at the tip but I think you want at least double that, what do you guys think?
  6. #76
  7. #77
    Max's Avatar
    Member
    Thanks trev, I'll have a look at that today.
    I just splashed out £1 for a old soda stream hoping there was parts usable in a robot. I know people use the co2 bottles but is there anything else I can use?
  8. #78
    kane's Avatar
    Roboteer
    The bottles are not really suitable for robot use; they are heavy and should not be refilled.
    Kane Aston
    http://www.makerobotics.com
  9. #79
    Max's Avatar
    Member
    Don't some people use them as high pressure buffer tanks?
  10. #80
    kane's Avatar
    Roboteer
    That would be a possible use. There are lighter alternatives though.
    Kane Aston
