hi all
looking for a piece of 4mm threaded aluminium round bar around 300mm+ needs to be ali due to weight.
i've had a search about can't seem to find anything suitable, anyone with some or contacts please reply
cheers alex
hi all
cheers alex
What are you going to use it for? I can't see any kind of threaded ali bar that small being useful in combat robots
It's for my product design course making an electro mechanical reading aid
I know it's not ideal but you could always just thread a bit of normal Ali rod with a die.
that is the other option but trying save a bit of time
Forget treading it with a die. Most ali that size is too soft and will gall.
At least bend in all directions at the same moment.
I could try to thread a titanium rod. But that will cost me a die, at least.
Is weight that much of an issue? I'm assuming you could find a steel threaded rod much easier.
yes weight is the issue ....i want to make it light portable etc....it's proably hard to imagine without a detailed explanation of my product which over the interent is quite hard
thanks guys
How long do you need it?
You could look into M4 Ali Bolts.
Steel threaded rod M4 300mm long. 21 grams, pricetag, per meter a few £ in any serious DIY shops.
Aluminium threaded rod M4 300mm long 7 grams.
Titanium threaded rod M4 300mm long 12 grams.
How much is that 14 or 9 grams worth?
