Results 1 to 10 of 10
Thread: Feather weight
    Max's Avatar
    Member
    Hi pugster,
    For a simple feather weight I would recommend:
    -2 Argos 12v cordless drill motors (12.50 each)
    -use the 12v batteries from the cordless drills
    -2 blue marine escs off eBay ( about £25 I think)
    - 2 100mm Robo-challenge blue wheels
    - giantcod transmitter and receiver (£25)
    - v-tail mixer off eBay (£5?)
    - 10mm hdpe armour
    -5 mm hdpe base
    Probably looking at a minimum of £120
    have a check through the whole featherweight section.
    Loads of people ask the same question, and get loads of the same answers.
    for a first fw best follow the advice you have been given argos drill motors and batteries and an electronize esc. £150 probarbly for a nice one
    Max had a good shopping list
    Alex had a good explanation of a fw
    only thing is go for 10/12+mm thick armour for a real competition ready bot
  8. #8
  9. #9
    the control is pretty good but there is a slight pause when going from forwards to reverse. i used black ones that claimed 50 amps in both direction, very tempermental.
  10. #10
    I've got 2 of the blue 1s running my 4x4 robot and i find it a bit twitchy
