Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Batteries
  1. #11
    So are you using 9.6v packs in series to give 19.2v on 24v motors ?
    I thought you had a 24v system where you will require 10-12 amps.
    I use about 5 amps per fight on a123's.
  2. #12
    component shop sell 12v 4.3a and 4.6a 50amp discharge packs btw.
  3. #13
    50amp discharge isn't enough, you would need at least 5packs in parallel (so 10 in all if they're 12v packs). As you're 4wd you will need more power than most.
  4. #14
    Ouch, don't think I could afford 10 packs if they only last one fight
  5. #15
    What are you using now , hawkers ? Do they last ok ?
  6. #16
    hawkers are lasting 2 fights, but its the size and weight I need to get down before I can think about a weapon system
  7. #17
    Changing to Minh / nicd will prob half the battery weight , a123 would be a little lighter, so what is your batt weight now ? Probably 12 kgs so would be 6 kg saving would that build a weapon.... wouldn't think so I think smidsy is a rambot ! Get better batts for more speed and power.
  8. #18
    So 6 12V packs will save weight for a better scoop and that should last 2 fights?
    my hawkers are 10kg the pair
  9. #19
    I bet you could save half the weight, but I don't think they would last 2 full fights. How many amps do you use a fight ?
  10. #20
    Not too sure, but my fully charged hawkers were running low in my last fight at whitwick, hence why I wasnt pushing much
