Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Batteries
    Sorry for another thread but I'm after some lighter 24v batteries for smidsy but don't know a good place to find any, anyone it any good places? What I'm really after is Nicads or Nimh but I don't know what packs I could use that can stand the discharge
    buy craigs a123s in the for sale section (unless they've been sold already). better than nimh or nicd.
    If your on a budget go to vapextec on eBay for cheap Minh packs
    They are on eBay not sure if they have their own website.
    they do indeed have a site
    http://www.vapextech.co.uk/
    I thought I would need a higher discharge rate as their only rated too 30a?
    Can't remember the discharge rate but I thought it was closer to 50amps PER PACK you will need 3 or 4 in parallel to give around 10 -12 amps ish !
    So would 3 4300ah 9.6v packs per bosch be alright?
  8. #8
    $$@@ me , Per Bosch 6 you mean ?. I only had 3 of that size 4300 x 3.
    Some robots use 3300 x 4, some got away with 3300 x 3 but of a pack goes down
    In a fight then you will cook the remaining 2 packs.
  9. #9
    aight, you'll need 6 total 12v packs 4.3ah or similar sized packs. wired in series into 3 24v packs then wire those 3 packs in paralel.
    vapextech only have 3 12v packs in there store, the highest mah being 4600, and costing £34 ea. so 6x£34 = £204
    craig's a123 packs are £60 ea so £180 for all 3. cut off 2 cells from each pack leaving you with 3 28v packs and 6 spare cells. then use the turningy accucel 8 charger ($43 off hobbyking) to charge the packs. would probably work out slightly more due to postage etc but would be alot better.
  10. #10
    Taking out the a123 stuff, 6 packs, all in would last one fight?
