Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Striker
    Awesome! Sounds very interesting, be good to see a 4Bar lifter in play.
    Cant wait to see it come together
    Try to limit the amount of elbow fittings you have between the buffer/valve/ram, they really reduce flowrate. If you want it to have more speed it might be worth using a quick exhaust valve to fire it.
    if you can;t get rid of the elbows try and change them to sweeped fittings or use some extra flexible pipe. What size push fit do you have in the ram? Also what is the flow rate of the valve?
  8. #8
    make a new one, the most commercial rear clevises are made from heavy cast iron. make a new one from hdpe or nylon. you also have 3 90 degree bends (one on the t). if you put a female 1/2 bsp push fit to 12mm pipe then bend it round into your valve it will provide alot more flowrate.you can put a t in the 12mm pipe just make sure the tube from the buffer tank to the valve goes accross the straight part of the push fit.
    the flowrate of 8mm tube is only 7.75 l/s, is it possible to go up to 12mm? the tube size is probably the limiting factor in your system. also how big is your ram?
  9. #9
  10. #10
    Not hard to make one, just use bolts to screw into the bottom of the ram
