Results 31 to 40 of 43
Thread: Good Websites for Newcomers
Threaded View
    Thought i'd start a list of websites we all use and pretty much know off by heart for newcomers to the sport to use as a reference for where to find various components. I'll probably forget some, so add if you see fit. Apologies in advance if I miss anything out in the description of your website, i'm just putting the main things in and people can have a look for themselves
    Roboteer Forums
    FRA:
    http://www.fightingrobots.co.uk/forum
    UK Antweight Forum:
    http://robotwars101.org/forum/
    Australian RoboWars Forum:
    http://robowars.org/forum/
    Event Organisers
    Robochallenge:
    http://robochallenge.co.uk
    Robots Live:
    http://robotslive.co.uk/
    Roaming Robots:
    http://www.roamingrobots.co.uk/
    Components
    Gimson Robotics (motors, wheels, actuators)
    http://www.gimsonrobotics.co.uk
    Robochallenge (wheels, motors)
    http://www.robochallenge.co.uk
    Component Shop (batteries)
    http://www.component-shop.co.uk/
    Giant Cod (radio gear, servos, batteries, motors, most things we use actually...)
    http://www.giantcod.co.uk/
    Technobots (connectors, fixings, LEDs, cabling, speed controllers)
    http://www.technobotsonline.com/
    Robot Power (Scorpion XL, XXL and Sidewinder speed controllers)
    http://www.robotpower.com/
    Argos (cheap drill motors)
    http://www.argos.co.uk
    Vapextech ebay store (batteries)
    http://myworld.ebay.co.uk/vapextech/?_t ... 4340.l2559
    Dimension Engineering (Sabertooth speed controllers)
    http://www.dimensionengineering.com/
    Banebots (wheels, motors)
    http://banebots.com/
    Electronize (Electronize speed controllers)
    http://www.electronize.co.uk/index.htm
    RS Components (Electronic Components)
    http://www.rswww.com
    HPC Gears (gears, belts, chain, sprockets, pulleys, custom fabrications)
    http://www.hpcgears.com
    Botbitz (speed controllers)
    http://www.botbitz.com/
    Materials
    Direct Plastics (Engineering Plastics)
    http://www.directplasticsonline.co.uk
    JL Steel (Hardox)
    http://www.jlsteel.co.uk/
    Material Cutting
    Clydeview Engineering
    http://www.clydeviewengineering.com/
    Draftek
    http://www.draftek.co.uk/
    Calculators
    LED Resistor Calculator;
    http://led.linear1.org/1led.wiz
    Timing Pulley Calculator:
    http://www.sdp-si.com/cd/default.htm
    Spinning Weapon KE Calculator:
    http://www.teamcosmos.com/ke/ke.shtml
    Drive and Battery Calculator:
    http://architeuthis-dux.org/torquecalc.asp
    Magnetic Force Calculator:
    http://www.kjmagnetics.com/calculator.asp
    Motor Power Output Calculator:
    http://www.magtrol.com/support/motorpower_calc.html
    Robot Speed Calculator:
    http://www.technobotsonline.com/robot-s ... lator.html
    Torque Conversion Tables:
    http://www.numberfactory.com/nf_torque. ... ervalue=90
    Shape to Weight Calculator:
    http://www.matweb.com/tools/weightcalculator.aspx
    Guides
    Drill Hacking Guide:
    http://www.wa4dsy.net/robot/drillmaster/index.html
    Electric Exe Guide:
    http://www.robowars.org/wikka/ElectricAxeWeapons
    Torque conversion app:
    http://www.numberfactory.com/nf_torque.html
    Pneumatics Help and Guides
    Pneumatic Systems Information:
    http://www.teamonslaught.fsnet.co.uk/co2_info.htm
    Pneumatic System Build Tips:
    http://www.teamdavinci.com/understanding_pneumatics.htm
    Pneumatics Guide:
    http://www.technobotsonline.com/design- ... obots.html
    Pneumatic Guide:
    http://howto.killerhurtz.co.uk/pneumatics.htm
    Comparison Tables
    Plastic Comparison Table:
    http://www.machinist-materials.com/comp ... astics.htm
    Metal Comparison Table:
    http://www.simetric.co.uk/si_metals.htm
    Steel Comparison Table:
    http://www.westyorkssteel.com/products.html
    Graupner Motor Comparison Table:
    http://homepage.ntlworld.com/edward.mat ... aupner.htm
