what should i use to cut polycarb for myant weight![]()
Jigsaw or hacksaw for antweight sized bits.
We use a jigsaw with blades like below for Mutes poly but its 12mm thick so hacksaw would be fine
http://www.screwfix.com/p/multipurpo...ack-of-3/21572
ok how do you stick it togethor
How do you stick the polycarbonate together and what with is what I was trying to sayOriginally Posted by Pugster2002
I would not try and stick it together, I would screw it together.
For the 1mm poly i used on my ants i either just cut it with a pair of scissors or used a sharp modelling knife and cut a straight line in it with a ruler and then bent it, that way it broke along the line making it straight.
It's easy enough bending polycarb to the shape you want and screw it together
For 1mm I use tin snips, you can also score it deep and then snap it.
It will glue with super glue if its clean.
I have cut up to 2mm poly carb with a sharpe knife and a metal ruler.
Been able to bend up to 2mm polycarb by hand
At about 3mm polycarb I would recommend hacksaw/ jigsaw that kind of thing.
i used polycarb (1mm) on Captain slow... it just shattered
