Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
Thread: Bruiser II
  1. #31
    up the voltage?
  2. #32
    What speed controller are you using ? I get the feeling the motors will draw some considerable power.
  3. #33
  4. #34
    Are they the 25A versions ?
  5. #35
  6. #36
    @ 19.8 V we had the problem Kashei's scorpion XXL started cutting out on the Speed 900 MSR 12-54 combination with 100mm wheels. We solved it with a Sidewinder.
    As the copies have a higher current draw, it could be that 25A ain't enough.
    On the other hand, if the wheels ain't too grippy, it should limit the power used.
  7. #37
  8. #38
    Those side pods look very well made!
    look forward to seeing you guys at the GSL again, we've got to represent Suffolk!
  9. #39
    Simplest solution if the speedo's cut out on overcurrent, less V.
    Something I think will be needed whatsoever.
    Those cheapo's run a lot faster than a Graupner Speed 900. I messured them 11000 rpm @12V
    11000/12=900 rpm/v
    900*14.4V=12960 rpm
    Gearratio 5-1. 2592 rpm on the wheels.
    0,125m*pi*2592= 1017m/min=61km/h
  10. #40
    How much!? The stats on the seller's page say 6700 rpm no load at 12v!
    http://www.ebay.co.uk/itm/12-v-ELECT...60160129600452
    Well that changes my predicted measurements slightly....
