Results 1 to 8 of 8
Thread: Axe weapon
    Max's Avatar
    Member
    Hi,
    Could you use a drill motor (without the gearbox) to power an electric axe at 12v?
    If so roughly what gear ratio would you need for a 30cm long axe with a 1.5kg axe head?
    you'd be better off using a more powerful motor but in theory a 12v drill motor could work for an axe if geared properly. it might be better to keep the gearbox on then gear it down again for a small ratio with chain though.
    1.5 kg axehead??? The 12mm axle from the drillmotor will be very gratefull.
    In Kashei we use a speed 900, a large reduction gearing, 12 steel arm and a Coldsteel 600 grams Spike Hawkaxehead
    And I have to admit, we needed to change the mod 1 steel gears to mod 2, because after a few fights, the gears were wearing down visibly.
    I've had a quick look an that seems like a nice design, run that at 18v and it could make a good weapon for people that don't want too run pneumatics
