Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Which connectors to use? :)
    i use deans :P with my fw
    We solder everything. Less space, less weight, less points of failure. And cheaper too.
    Max's Avatar
    Member
    In Colin I used some crimp connectors but they were rubbish- they get very hot, keep coming off and I think restrict current flow (but that good have just been the drill battery). I dont recommend them really for robot use although they were very quick, didn't need soldering and very easy to change what is connected to what
    Deans for me... You shouldn't have more then 2 connections on each terminal.
    +1 for Deans.
    As well as using them as my main link and battery connectors, I also use them on my motors. I have removed the terminal block connectors of my Scorpion XL and soldered directly to the board, but during an event if I need to remove a motor for maintenance, it's much quicker and easier for me to just unplug the connector rather than trying to de-solder the wires. Just need to remember to stick a cable tie round the two halves of the connectors when I put the motor back in, to reduce the chances of them popping apart and costing me a battle.
    EDIT: You posted as I was typing, so I'm pretty much saying what you've just said
    I've used Tamiya connectors in the past, but found them to be more unreliable. The wires need to be crimped into the male pins very well and they need to have good contact when they're mated (can get bent out of shape) as I found on more than one occasion (perhaps my poor crimping) that the power was intermittent. The same principle applies for Deans connectors, but those pins are much stronger and a good connection is usually guaranteed.
    I use Andersons or Powerpoles.
