Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: hdpe - joining
    As thick and coarse as possible.
    Particle board screws I guess
    The thinner piece is drilled trough with the same size as the outer diameter of the tread. The thick piece is predrilled with the inner diameter. And don't overtorque.
    i found large wood screws work fine
    I just use chipboard screws, seem to work fine.
    I used wood screws of some sort (I think they were standard) and when put together well they make for one heck of a connection, to the point where on several occasions our cordless drill/screwdriver (one of the lucky ones that still serves as a drill!) couldn't undo them.
    In my materials lectures we have been researching processes like laser and sonic welding as well as extrusion welding for HDPE. I was hoping that I could hire an extrusion welder and build the armour for my robot with that but I cant find any companies that hire them out. Any ideas or is it overkill?
  8. #8
  9. #9
    Quote Originally Posted by Eventorizon
    I own a handwelder for HDPE, but it seems the welds are more brittle than the mother material.
    I learned to back the welds uo with some bolted in/on supports.
  10. #10
    There are a few robots about that have 'welded' hdpe shells , you can use a really powerful hot air gun and hdpe welding rods
