Results 1 to 7 of 7
Thread: BEC circuits
    Hook it up to a power source and put a multimeter across the red and black (or red and brown) servo connection. Then you will be able to tell me
    i've got a bec in one of my robots and i just have it from the battery to the reciever. i havn't got it going through a channel with anything plugged in.
    Yes you can. Wire + and - into the robots circuit, and plus the servo lead coming from the BEC into any spare rx channel. No need to plug a servo cable in the other end unless you need that channel for something. In Satanix its plugged into the rudder because that doesn't do anything on any bot the TX is used for.
