I think it will be the one I go for, any issues with ordering it from the states?
one i ordered took about 2 months to get here, but apart from that no.
Im putting a fuse before each esc, im using electronize, 15a, drill motors and 18.5v lipo about 4000mah. Can anyone suggesy a fuse size for before my esc?
Clue is in the esc your using ...... 15Amp ????????
I've run 25A fuses in line with Electronize 15A controllers before without any trouble. Over-rated enough that it doesn't blow at every sign of a 15A current, and under-rated enough that it'll still blow before doing any damage to the speed controllers.
Perfect ill get a few 25amps then. What size of fuse do you think to place just aftery lipo battery for the full system. I was thinking 100amp?
What is the 'C' rating of your pack(s) again? Just multiply that by your Ah rating and that will give you the maximum current the pack can output (if I picked that part up correctly). Then put in a fuse slightly lower than this.
I havent got the lipo pack yet but itll be 18.5v and either 3500 or 4000 mah
The 15a Electronizes have a 40a peak rating so I use 30a fuses.
is that a 30amp throughout the full system or 30amp before the speed controller (or after the battery?)
