Page 28 of 34 FirstFirst ... 182627282930 ... LastLast
Results 271 to 280 of 333
Thread: scruffy
  1. #271
  2. #272
    well im hoping the curved side will give the drum/ vertical spinners less to dig in to
    right bit of an update got the actuator fitted in and allot of the welding i now done
    next i need to get its new face made and make proper mounts for the LED/eyes, make a few interchangeable scoops, make the top plates, mount everything, paint it and wire it up
    oh and some how make some 20mm long spike out of ti or carbon steel with a m4-m6 tap so will probably have to be 15mm diameter as i can really trust the goth spike to hold up anymore
  3. #273
    Looking good! The curved sides will work well at deflecting damage, but I would be mindful of drums for getting a bite - I don't know if it will so much with the fact that they are curved, but it'll definitely deflect a lot of the damage regardless!
    Any plans for electronic upgrades or anything? I remember you mentioned about moving back up to 4S again back at the champs...
  4. #274
    got a bit more done to scruffy 3 a have plans for scruffy 4
    the top plates are only 3mm aluminium but i will be adding some 5mm hdpe to the and the front scoop will be more like scruffy 2s but probably wider, i will be going back to a 4s and adding a gyro so it will have the power of scruffy 1 with the control of scruffy 2 hopefully..... also the scoop will be interchangeable between a couple of designed
    night fury 2 has taken a bit of a back burner due to needing about £50 of materials and the fact that its taking me ages to get my heavyweight and scruffy 3 going but as it will probably be the easiest build i will probably look at ordering the parts soon
    couple of update pics
  5. #275
  6. #276
    yes ryobi drills, its the original scruffy drive, same as night fury
  7. #277
    Looks great, what are the dimensions thus far it looks really small
  8. #278
    its 500mm wide, 300mm long and 170mm high excluding the prong scoop bit
  9. #279
    What esc's will you be running? still going to be sticking with the cheapo chinese ones?
  10. #280
    probably they have done me well so far and with a gyro in the mix it should improve the handling
