I've wired it up for a test run here's the ivd
looks very nice :P
Good stuff![]()
new incarnation of scruffy .... probably gonna call it scruffy devil, have a couple of red LED's for eyes on the lifter
Motors 2x ryobi drill motors 600rpm
5mm steel round all sides
2mm steel base
2x 7.2v 3800mah battery's in series
lifter is 1 or 2 car seat actuators
2x 100mm wheels
and i have a sabertooth dual 12a controller or might just use a couple of boat 1 as i have found some that can run on 14.4v for about £13 a piece and a v trail mixer
Nice find on the Break Pipe connector! Effectively gives you a long 3/8 UNF nut. Just need to find one 14mm long to match the thread on drill shafts.
the total length is about 30mm but there's a bit in the middle so you only get about 11mm of thread either side i had to open up the hole the get the screw in
Interesting,,,, you could always cut it down I guess.
got the motors attached to the base plate used screw inserts with an m6 thread and i think i will have to use 1 of the 2 actuators...... i have the length of 5 x 100 x 1000mm flat bar which will do the sides and back and I've ordered a piece of 5 x 120 x 400mm which will fit the wedge front
go the 5mm front plate and checked all the weights mostly using this website..... http://www.matweb.com/tools/weightcalculator.aspx
should have just over 4kg to make the lifting arm and top armour
thats a good website used it for many years
good luck with the build![]()
