Page 16 of 34 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 333
Thread: scruffy
  1. #151
  2. #152
    the only sketches i tend to do are a sort of floor plan to make sure i can get everything in the shape, i tent to go with a general idea and let it build up that's how scruffy got its look
    my next 1 after this will be a growler ish style robot, ive already got some of the steel just trying to find some decent drive motors as the 1s i use to get arn't available anymore
  3. #153
    i've been been estimating how much weight i have left on the bot and i might have enough to add some additional bolt on armour on the sides i think i can get away with either 5mm thick cheep aluminium or 10mm plastic like hdpe, my main problem is which might protect better against spinners
    i was looking at direct plastics at
    hdpe
    acetal
    polypropylene
    rg 1000
    any ideas on which would be better, at the end of the day their sacrificial and they would have 3mm steel behind them so if they would all work to about the same level then i would just go for the cheapest
  4. #154
    HDPE for sure.
  5. #155
    ok thanks its also 1 of the cheaper options
    do spinners tend to chew and flex it rather than just bending and break it, im also wandering how cheap 5mm aluminium would fair
    also is grade 500 hdpe any good, found some the right size on ebay
  6. #156
    HDPE 500 is the softer cheaper version, very shatterproof and the most easy (still not easy in itself) to weld.
    It's what the Hannibalito's are made off.
    And I think Hannibalito 3, build in 2007 and not spared in the amount of fights, is proof of the quality of the stuff as armor. On the other hand, it's in certain spots up to 30mm thick.
    Polypropylene is useable, but it's harder and a tad less shatterproof than HDPE.
    Acetal is even harder, but a lot more brittle.
    RG 1000 , no comments there.
  7. #157
    rg 1000 is the poor mans nylon. Not useful for much for us. Jamie tried to use it a while back in drumroll. Didn't work out so well.
  8. #158
    thanks for the info
    sound like the hdpe is the best to go for on top of the steel shell
  9. #159
    Quote Originally Posted by typhoon_driver
    rg 1000 is the poor mans nylon...Jamie tried to use it a while back in drumroll.
    Indeed. I chose it for exactly that reason...I was a poor man at the time
    Nice stuff to cut/work with but not the best building material, especially for chassis bits etc.
    Difficult to say how it compares to HDPE; I'm now just in the habit of using Nylon for chassis and HDPE for armour (if needed).
  10. #160
    RG1000 sounds much cooler though....
    What was that exotic metal you used on your Drum Jamie?
