Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 84
Thread: New FW- doorstop
  1. #51
    i used this website to calculate the weight of the the Armour for my 4wd that got 8mm steel round the sides but i had to use 3mm on the base and aluminium for the top plate to keep it in weight, and i just weighed the wheels motors etc and its about 12kg without the wepons
    http://www.matweb.com/tools/weightcalculator.aspx
    it was drill powered not speed 900
  2. #52
    Size of wheels? 100mm?
  3. #53
  4. #54
    I'd be amazed if normal drills would handle that. Ours destroy themselves with smaller wheels and lower voltage...
  5. #55
    Very fast machine then.
    Unless you got a strange set Speed 900 replica's. What size of axle did they have?
  6. #56
  7. #57
    I ment, what axle does the replica 900 have. There are 3 major types.
    5mm, fast runners, ment for applications as battery-leafblowers and such.
    6mm, speed 900 size.
    6.35 - 1/4 Ment for car applications.
  8. #58
  9. #59
    Fast runners then. 12K rpm @12V
    @22.2V those want to run 22.2K rpm. With a gearratio of 7.5-1 the theoretical topspeed should be 71km/h, given time.
    Unfortunatly, it will be something about 35 km/u, and the motors will run half speed, drawing more amps. Don't close of the vent holes, and maybe adding a small fan to keep the air flowing trough the motors at all times.
  10. #60
