Originally Posted by mr_turbulence
And getting good tooth engagment at that speed is very very easy....
According to me is 2000 rpm perfectly serviceable for a 350mm disk.
8000rpm engages fine with single tooth... 2 teeth engage fine at 5000rpm... just talking from experience.
Been a while but now I have all the parts attached is the wiring diagram I think works... can anyone confirm?
[attachment=0:245taqkd]Weapon Relay Wiring Version 1 Diagram 1.pdf[/attachment:245taqkd]
Both systems work by controlling the negative. Part one... the power goes into the 100A relay's low Amp side then into the battle switch for control. When activated the battle witch lets the input from the 100A relay go to negative...
Now the other system kicks in... the 22.2v goes straight into both speed 900's then into the positive of the 100A relays high Amp side. When fired by the battle switch the 100A relay allows the speed 900's output to go to negative...
I hope I have explained that right...![]()
