Looking like it'll be £30 for the 12V version and £33 for the 18V.
Two reduction options will be available, 36:1 (as before) and 24:1, which would provide performance similar to the drive in Cobalt. All gears will also be available separately.
The exposed section of shaft is indeed longer (43mm) while the body itself is more compact owing to a smaller bearing and lack of plastic inserts which took up considerable space in the GR01.
The overall size is 40x40mm down from 45x45mm previously.
At the moment the shafts are out getting flats milled on them (which should expand the range of mounting options), once they're back then more pictures and specifications will follow.
