i know its probably a dim question but what thickness steel would be equivalent to 1mm titanium?
all depends on the grade
1mm good grade steel is as strong as 1mm good grade titanium.
2 differences.
Steel is heavier.
1mm Ti weights as much as 0.6mm steel
Titanium is a lot more expensive.
Titanium is considerably tougher than steel.
Having worked in steel, on and off, for most of my working life (35 years) I can tell you that bending or shaping mid grade Ti is a bloody site harder than good mild steel of even twice the thickness.
Skink's flipper blade is 1.5mm Ti and took some effort to bend to shape.
Skink is now over five years old and despite hundereds of fights I have never had to re-shape the blade.
This would not be true if it were steel.
Mike.
I've resorted to using some 3.5mm plastic, no idea what it is but it shouldn't take that much damage and due to my bad design, I only had 200g spare. Will keep the same design, but have a new body shell after Kidderminster... Probably![]()
anyone know of a place where i can get titanium sheet cut and delivered? looking for 2 sheets of 1.5mm grade 5 107mm by 520mm
Tjones Fabrications my sponsors might be able to help 01773607017
alex
Thanks, I'll give them a call on monday
We have some 1.2mm titanium if thats thick enough? not entirely sure on grade but I can check on monday. Can be cut to any size as I have a reasonable amount of it left.
Pm'd
