Any system using pneumatics need a 1000psi relief valve, except low pressure designs where the reg goes directly on the bottle.
This means the Low Pressure relief valve will handle any overpressure issues downstream the regulator.
Once you start adding more parts between bottle and reg, you need both pressure relief valves. One on the FP side, and 1 on the LP side, set at the lowest pressure rating of parts in your setup.
