Page 1 of 7 123 ... LastLast
Results 1 to 10 of 66
Thread: Full Tilt
    I am starting the build thread for my new robot Full Tilt. A new concept I believe hasnt been done before and i hope will entertain as well as be competative. My Avatar is a render done by Martijn Benschop (awsome too) so i can see what it will look like before i put metal to grinder. Origionally was going to house a mini Etek for the weapon will now sport a Mag motor to start with...if we feel we need more power then we will upgrade to a mini Etek or Lem.
    With a 4x4 configuration running on mag c40's on a 9 to 1 ish gear ratio with 10 inch solid rubber wheels it wont be as fast as Envy Or Thor but will have tons of pushing power from the tourqe produced from the good old maggies. The weapon will be central mounted and geared to 36 to 1 giving over 300 hp with a mini Etek. way ott so lowering to a mag might work just fine but ever upgrading is the teambud way. The drive will be running on the custom made LAMBERT POWER DRIVE gear boxs with chains to the other set of wheels. the weapon will be interchangable with many scoops of different shapes and sizes to choose from adapting to which robot it will fight. Rotating 360 degrees at an estimated 1/4 second per revolution its gonna be fun learning to work the weapon never mind learning how to drive it.....lets face it i am not the best driver.
    Parts are almost collected and manufactured ready to build and will be posting pictures as i progress. (probably Joey or Liam actually
    Hopefully ready for kidderminster. (gulp)
    And here's those pictures - good luck Shane, hope this goes well
    I'm really looking forward to seeing this one. It should be an amazing thing to watch
    lets try and get this straight, its basiclly the first effective electric flipper?
    it's a 360 degree electric lifter
    but with 4 revolutions every second and that amount of power, that in theory could be a lifter or a flipper and depending on scoop position and design even an axe?
    More photos for Shane, looks like it's coming along nicely
    These are the Lambert Powerdrive gearboxes, to quote Mr. Swan:
    Quote Originally Posted by swanaldo
    the gearboxs were made by the great Mike Lambert and similar gearbox were in his famous robot Dantomkia. Its a pleasure for Teambud to use The Lambert Powerdrive. they are custom made to my specs for Full Tilt
    Can't get better than that really
    The beginning of the weapon drive
    Two of the 10 inch drive wheels
  8. #8
    Thanks Joey....Just a couple of pick of parts....build starts Wednesday. Will post pics for those interested.
  9. #9
    Oh and before i get pointed out anymore...the motor gear is loose on and the bolts holding the motor on were all i had at work...just together for piccys.....
  10. #10
    Very nice bit of kit Mr Shane and Mr Lambert
