Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: pnneumatic axe robots
    a rack and pinion axe system is usually custom machined into the cylinder rod, i don't know of any rams that come as standard with teeth in
    you could use an accelerator mechanism or mount the end of the ram to the axe arm. i dunno how they make them air tight, i have never made one
    The rack on Hell's angel was cut out of the piston, and any rack like that is never totally air-tight. Tiny Hurtz has an off-the-shelf rack peice welded onto the end of the ram.
    The seal in a normal commercial piston is wide enough to limit the losses over the rack to a minimum. It never slowed THz down, didn't it?
    I believe there was only 1 FP axe in use the last years, Obsidian. But that was a fully custom job.
    For feathers it's in part the ease to find valves. Not many 5/2 or 5/3 FP pneumatic, affordable valves on this world.
    And using 4 Burkerts to control the FP axe-system, ain't cheap, nor light.
