Page 18 of 21 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 201
Thread: Featherweights - Active weapon rule
  1. #171
    How about this for a compromise:
    The feathers with weapons are split into two heats as normal and all the non weapon feathers names are put into a hat.
    The first six or eight drawn out are split into two groups with three or four going into each heat.
    This way boxes get a chance to compete but you don't end up with fights dominated by them.
    What say you guys?
    Mike.
  2. #172
    Can't believe this is still being discussed.
    Alan has said he's going to run a similar format to is, where each fight contains all the robots and they score points. Winner comes from that.
    Plus any robot which is being boring gets attacked by the houserobot.
    Sorted
  3. #173
    in a nut shell there jonno
  4. #174
  5. #175
    limiting speed is a bit ott what makes boxes entertaining when they are is their sheer speed limiting it is one hard to enforce and 2 bad for the whole purpose of what Alan was talking about
    people have said about lowering the weight limit for boxes,...tbh i think this would have to be drastic ie 7kg or less as its easy to build a box with little weight. however doing this does limit the motors etc you can use and the boxes will still remian and be even slower and boring
  6. #176
    What is there to gain from reducing the weight for rambots?
    Yeh sure it would discourage people from making them, but for half the people they build rambots because they're starting out so lack of choice, and the other half are people that use the full weight limit to it's up most potential and make very powerful, fast rambots, Satanix, 540, Bonx etc....
    There's no way Bitza could have taken on the spinners at the 2011 Champs if it didn't weigh the full 13.6kgs.
  7. #177
    personally I find limiting the weight of boxes a real odd idea
    as it is right now, SOME boxes still fall in the very entertaining category solely because they can use the weight they don't invest in their weapon, in stronger motors and a sturdy wedge of sorts, which allows for some potential spectacular ramming action.
    If you take that extra mass away from the drive-train, literally EVERY box will become boring.
  8. #178
    yeh thats what i was saying i too disagrre with the lowering limit as an idea
  9. #179
    Quote Originally Posted by Hard Time
    Make them look cool: Flames, objects (Like Ceri's ninja sheep), awesome paint jobs.
    Here's somewhere I can manipulate things, I formerly announce:
    The Twn Trwn memorial prize for best decorated featherweight robot in Kidderminster 2011!
    Bit long & it's just an idea thus far. If this works, we will have the best looking dull boxes in the world!
  10. #180
    ceri, you cant give it to yourself with your ninja sheep!
