Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Pneumatic Fittings
    Hi,
    I have got a 20oz C02 bottle
    http://www.amazon.co.uk/approved-20oz-C ... 083&sr=8-2
    and a Trev reg that came today but the 2 wont screw together
    I dont know the fitting on the bottle but the reg has a 1/4 BSP inlet.
    How would I be able to change the pin valve to something that would screw into the bottle and has a 1/4 BSP outlet???
    The bottle uses an US thread that is so close to 1/2 bsp it doesn't matter.
    You need another valve in between the Trevor and the bottle. That's the disadvantage of a pin-valve.
    Therefor, you need a ballvalve with a 1/2 bsp female inlet, but also with a pin-pusher.
    You can buy a seperate on/off valve for your bottle. The thread stays the same.
    Or better, go to a local paintball shop, and let them change it.
    Not, I guess you'll have to build it yourself, or pay top £££ for a machinist to make it for you.
    I suggest replacing the pin valve with an on/off valve. Less hassle, safer and lighter.
    The on/off valve should have the same tread as the pin valve. It's a rather standard thing.
    You can get these http://www.ebay.co.uk/itm/NEW-PAINTBALL ... 27b1369bba
    Problem is that you still have issues with co2 fitting and the flow of the valve isnt that good
    The flow of any bottle-valve ain't something to cheer about. That is why buffertanks or, old school liquid CO2 injection is used.
