The ramming bar pushes the robot away, not the robot.
The first battle has been posted: http://teamcorsairbots.proboards.com...fra&thread=110
And what part of the robot is on the floor to provide traction to that ram? You need to push forward or the ram has no impact.Quote:
Originally Posted by corsair_lightning
I know, I was just pointing that the ramming bar itself is powered by a motor.
That doesn't matter. If both robots have the same drivetrain, then a ramming bar will either do nothing or shunt them apart equally. It won't thrust a more powerful robot away.Quote:
Liar 2 vs Lethal Weapon
Classic Robot Wars Arena? lets throw that machine over the wall!!! Liar 2 packs plenty of flipping power and a superior speed to Lethal Weapon, as well as 2 wheel drive that allows me to be more agile, I'm gonna use all of that to avoid being hit by his disc, and to get my own weapon in. He may have (tivandium?) skirts, but I have a big thin wedge that is scraping along the ground and that is brought to the ground by the mass of almost my entire robot, which means I should be able to get under his skirts I think... Id rather get under his skirts than under his disc anyhow so that will be what I will do. When under, take him to the wall, and flip. With some luck I will score an OOTA straight away, with less luck his disc will bounce off the wall and he will be damaging himself as well as the wall. Repeat this really, while at the same time dodging that disc.
Good luck Tony!
lol, good. I'm quickly out of a tournament that's already utter fail. I'm not even going to begin to point out the dozens of fails in your fights, I'll let Joey do that though if he's willing. :P
And Jack, I dunno why you're saying his fights are getting better. They're...really not. :P
i think its revenge on you for (as most people put it) a lazy way of getting minesweeper 1.1 out
so can you shut up with this arguement as im getting a bit sick of it :?
please just learn to get along with him kody, im sure you have your reasons and he has his :roll:
*Sighs* Security, we have a Code D(Ko-dy :P ) situation.
*Security takes Kody out of the building*
Well, I guess this rivalry will never end. Add that to the fact that both Heretic and Starfighter have made it to the Crazy Bots featherweight finals, and this only intensifies the rivalry.
But anyways, I'll need tactics for round 2 in by Jan. 11, 2010, 11.59pm.
And no, it's not revenge. Truth or Consequences isn't a wedge, and therefore was able to not get impaled on your side spike. Also, I'm not going to assume that everyone's a perfect driver, and therefore, you accidentally drove down the pit.
