Side note on tapping Hardox/Armox... I was chatting to the Guhring guys at MACH 2016 and they told me about a different type of tap for threading very hard materials. I can't remember the name but I remember the process.
Rather than cutting the thread this tool reshapes the metal into the thread profile. As an example, for a M6 thread you drill a 5mm hole, but for this you drill a 5.5mm (Half way) and then the tap deforms the metal into a complete thread so you are never removing material in the process, just reforming it.
Also, since you are reshaping the material and not cutting it, the formed threads are much stronger than a regular threads and are harder to destroy. While the process requires more force it doesn't produce any more heat than a regular tap due to the change in surface area.
I've not bothered looking it up recently as I haven't needed to do any serious tapping but it might be useful if you find yourself needing to tap +4mm hardox with an M5 or greater thread.
