Results 1 to 8 of 8
Thread: Completely lost with component selection
Hybrid View
    Hi - welcome!
    Read this: https://www.riobotz.com/tutorials
    That'll get you started. In terms of recommending components, could you elaborate on your design a little more?
    Quote Originally Posted by emisnug View Post
    Hi - welcome!
    Read this:
    Well I'm planning on it being, in terms of drive, what looks like a pretty standard 2wd setup. Most likely just going to stick with a pair of 12v drill motors as it seems like pretty much the simplest way to run a featherweight drive system for a newbie, however I'm pretty confused regarding the electrics required for such motors.
    The bit that I'm really not sure about is motor selection for the weapon. The design that I've got in mind will need something with pretty high torque for a featherweight motor but I'm not even sure where to start looking!
    Quote Originally Posted by mackemforever View Post
    snip
    Welcome as a fellow newcomer i would really recommend reading that Riobotz PDF helps a lot with ideas + read through a load of build guides it helps you avoid mistakes.
    also for your drive look at some botbitz 85a speed controllers (http://ranglebox.com/product/botbitz...2-brushed-esc/) as they really the go to controller for brushed motors at featherweight
    Quote Originally Posted by daveimi View Post
    Read all the recent build threads and get to some events to talk to people
    I second everything in David's post, but especially this. Seeing what others did in your place helps to give you a perspective of what you need to learn as well as what is reasonable for your skillset. Some that I'd recommend are:
    * DotDominic's build diary on Ventator: http://www.fightingrobots.co.uk/thre...t-robot-please A simple 4WD pusher bot, will tell you a lot of the basics involved in part selection and construction.
    * R9000's build diary on Aegis: http://www.fightingrobots.co.uk/thre...d-lifter-aegis A 4WD LinAc (Linear actuator) lifter. Interesting to see how a design changes over time, and shows off some pretty useful stuff with modifying brushless motors to linacs to get more power out of them. Also a testament to how good a first feather can do if built right; Aegis made it to the top 8 of Insomnia 61, which is basically THE FW competition of the year, as well as winning the 20 bot Gladiator event.
    * qbnut's build diary on Battleaxe: http://www.fightingrobots.co.uk/thre...e-hammer-diary Just an all around solid build diary of an axebot, and may be more useful if you plan on working with metal.
    Hope these are helpful!
    In answer to your gearbox question, you use the gearbox that comes with the drill motor and attach a wheel to the output shaft where the chuck would normally be.
