Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: How to stop wheels spinning off their output shafts and Brushless drive
Hybrid View
    I wouldn't recommend drilling trough the output shaft of a drill. Seen it before, and it will give a nice weak point that will snap.
    On brushless drives. 350W/7.4V= 50 amps. 50amp esc's needed...
    But I think it will work nicely. After all, Hannibalito3.2 drives on 3S with 28mm diameter unsensored brushless motors.
    Do you not have reverse thread screws for them?
    Might sound abit basic, have you tried putting more washers on? - Defector has 6 on each side.
    Don't grease them. You want the complete opposite: the normal thread and the reverse thread bolt need to be locked hard to each other. The idea is if one starts to rotate the other locks up. Try some low-mid strength thread locking compound and crank them up hard.
    I wouldn't use much on the wheel's threads (if any) as if the gearbox goes it'll be a massive struggle to remove it, but the reverse threaded bolt could benefit from some. The suggestion above of sturdy enough washers, so tightening up doesn't flex them, is a good one.
    edit: although 6 is overkill lol
