Page 68 of 91 FirstFirst ... 1858666768697078 ... LastLast
Results 671 to 680 of 906
Thread: RogueTwo Robots
  1. #671
    RogueTwoRobots's Avatar
    Roboteer
    Status
    Offline
    Name
    Jamie McHarg
    Robots
    Drumroll II, Carcinus, Onyx & Coyote
    Location
    Aberdeen, Scotland
    Posts
    3,934
    Update
    Been doing a little work to Flatulence over the past couple of days. It's been sitting for about a year needing its armour completed and I've been putting it off for ages because I expected it to be fiddly and annoying to do.
    I was right, but got it done eventually. It's quite thin, at 2mm, but seems reasonably strong. The bottom half is 4mm HDPE which will stand up to the spinners a bit better, but I'm fully expecting all of it to take a beating. At least it completes the look a bit more. Ignore the multiple fail-holes where the armour layers meet:
    Currently weighs 1083g so got just under 500g for....stuff. The only thing I want to do is replace the ali flipper plate with a steel one with triangle wedges at the front to finish the shape off and offer some protection. Will also need to stick something on the top of the flipper plate to help it self-right as it only rolls halfway over before getting stuck.
    I'll never expect this to be a serious contender as I started building it two years ago and since then, despite not even having an event yet, beetleweights have already stepped up a level. But if nothing else, it's good fun to play with
    Jamie McHarg
    RogueTwo Robots
    http://www.rogue-two-robots.vze.com
    With great power, comes great reliability.
  2. #672
    Love it
    what voltage you running the servo off?
  3. #673
    Roboteer
    Status
    Offline
    Name
    Jamie McHarg
    Robots
    Location
    Aberdeen, Scotland
    Posts
    3,934
    Cheers Harry. The servo's just plugged into the receiver, which is getting a 6V, 5A feed from the BEC. Was originally using the BEC in one of the Botbitz ESCs but it was underpowered, especially since it's a beast of a servo. All good now though
    Jamie McHarg
    RogueTwo Robots
  4. #674
    SamO's Avatar
    Member
    Status
    Offline
    Name
    Samuel.Ottley
    Robots
    Endeavour (FW-Active) Mini E (AW-Active) Intrepid (FW-Being Built)
    Location
    Hampshire
    Posts
    178
    Are you going to finish the BW Drumroll?
  5. #675
    Roboteer
    Status
    Offline
    Name
    Jamie McHarg
    Robots
    Location
    Aberdeen, Scotland
    Posts
    3,934
    Probably at some point down the line, yeah. Not with that chassis though, would make a new one out of some thicker/more rigid material, and need to get a smaller diameter brushless as I planned to have the current one pressed into the drum tube, but I couldn't get a tube with a suitable ID so just plan to revert to a pulley transmission.
    Jamie McHarg
    RogueTwo Robots
  6. #676
    Jamie, okay cool. You could probably get away with overvolting that servo for a bit more speed and power if you needed it.
    cheers.
  7. #677
    Roboteer
    Status
    Offline
    Name
    Jamie McHarg
    Robots
    Location
    Aberdeen, Scotland
    Posts
    3,934
    Update
    Well it's finished, paint and all:
    Happy with it weighing in at 1.35kg. After several attempts at different attachments in order to get it to self-right - and getting nowhere - I eventually resorted to hacking the servo for 360 rotation, allowing the flipper arm to travel further back, turning the robot back onto its wheels. The downside is that I had to cut away some of the back armour which now spoils the look a little, but functionality over image!
    A lot of the wiring was pretty exposed due to that too so I've redone it all, doing away with the connector block and just splicing all the wires together where needed, and have been able to pack it down to protect it more. Finally, needed a bit of protection on the insides when the flipper is up and still had to add an LED, so bazinga:
    So that's that for Flatulence just now. Need to get some practice in controlling the flipper as going to 360 completely changes the dynamic of operating it, but nothing else apart from that to do
    Jamie McHarg
    RogueTwo Robots
  8. #678
    Mouldy's Avatar
    Roboteer
    Status
    Offline
    Robots
    Turbulence, Carbide, 360, 540, 720, 722
    Location
    Birmingham, England
    Posts
    2,250
    Love it
  9. #679
    Member
    Status
    Offline
    Name
    David Weston
    Robots
    Divinity Little Devil Baby Hell Stewie FIN Bulletproof Kill-a-Chav St Jimmy Satanix Hell's Angel
    Location
    Carterton, Oxfordshire
    Posts
    1,940
    Need to put it on a spring action trigger, either rudder on the remote or use a DPDT switch like I do, middle as neutral, full power either way.
  10. #680
    Roboteer
    Status
    Offline
    Name
    Jamie McHarg
    Robots
    Location
    Aberdeen, Scotland
    Posts
    3,934
    It's on the rudder channel already, it's just that I've been used to flipping a switch and letting go when it was set up like a normal servo on the throttle channel, where it would stop when it reaches its limits. Now I just need to familiarise myself with the new fire and retract movements, especially for quick, repetitive flips as I don't want to hold it too long in one direction or other and have the flipper either travel too far for a quick reset/attack or be stalling the motor too long at the ends of travel.
    It's not challenging, it's just to get comfortable with it so I don't have to think about it when in the arena.
    Jamie McHarg
    RogueTwo Robots
