Results 1 to 9 of 9
Thread: Heavy questions
    Member
    Status
    Offline
    Name
    David
    Location
    Blackpool
    Posts
    1,731
    Would a really tough fast narly brick without much of a wedge be good to chuck in with spinners and wedges?
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    AW: Amai, Ikari, Osu, Ramu / BW: Shu!, The Honey Badger / FW: Azriel / MW: Jibril, Kaizen
    Location
    Somewhere on the Wirral
    Posts
    891
    Comes down to driving skill in that instance one would think if the brick doesn't have any active weaponry and/or exploitable ground clearance in the case of wedges. Against spinners, depends on how slab sided it was.
    FW: Azriel
    MW: Jibril, Kaizen
    Member
    Status
    Offline
    Name
    David
    Location
    Blackpool
    Posts
    1,731
    It'd just be built for fun and to have a go at building a cheap heavy.
    Theo's Avatar
    Member
    Status
    Offline
    Name
    Theo Beech
    Robots
    Voodoo - MW, Vulture - HW, BW9 - FW, Oberon - FW, ICEBT - AW
    Location
    Manchester
    Posts
    247
    Have a go! Though I'd at least fit it with some wedgelets if you're not wanting to do a full wedge
    Member
    Status
    Offline
    Name
    David
    Location
    Blackpool
    Posts
    1,731
    I can build a wedge, it was just an idea of thought of.
    Member
    Status
    Offline
    Name
    David
    Location
    Blackpool
    Posts
    1,731
    To ask a stupid question is it worth building a heavyweight? I'm right on the limit of clicking "buy" on the components, but want to check to see if the EO's plan on running spinners more and more at events first?
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Posts
    891
    The arena at Robots Live! cannot handle spinners of any description at the moment. Extreme Robots can but in the MW/HW categories, it is limited to 125mph. As far as HW spinner numbers go, I can think of Aftershock, Donald Thump, Tauron and Magnetar as being some of the big hitters at the moment but I don't think I've ever seen them all together at the same event.
    If you really didn't want to face a spinner, you could mention it to the EOs at EXR but that might limit you to whiteboard/show matches only.
    FW: Azriel
    MW: Jibril, Kaizen
  8. #8
    James Williams's Avatar
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Neophyte, Meteorite & Exabyte (FW)
    Location
    Birmingham
    Posts
    87
    Hi David
    In case you haven't seen it yet, Extreme Robots have released a plan regarding how they plan to run events. They specifically mention a non-spinner HW division, so if you don't want to face spinners, you won't have to.
    https://www.facebook.com/groups/roam...6725914914022/
    James
    Team Phyte
  9. #9
    Member
    Status
    Offline
    Name
    David
    Location
    Blackpool
    Posts
    1,731
    Thank you for the info, have contacted John today.
