REC Gearbox is a project that has been tested on our Team robots since 2012. After a hundred of fights, tests and fails, here you get the best improvement possible on drill based gearbox !!
Diversity
REC Gearbox can be produced at differents final ratio as 6:1, 24:1 and 36:1, meaning that you can select the one that best fits your project.
Power
REC Gearbox break the wall of RS550’s motors type, handling also RS775 motors on 24:1 version.
No stall
The most significant improvement on our Gearbox is the replacement of all parallel pins to taper pins, so no loose pin, no instant stall, no smoke!
Robust
REC Gearbox is made from 45x45mm 6061 Aluminium alloy and have 12x M6*1mm threaded holes.
Dual bearing supporting the main shaft, make sure that everything will keep running even under big radial loads.
General dimensions:
Square – 45x45mm
Main Shaft length (12mm) – 38mm
3/8 UNF Theaded shaft length – 15mm
Total length – 145mm (including RS550 motor)
Weight – 473g (including RS550 motor)
Prices:
Plug and Play
6:1 version – 30£ including RS550 motor.
36:1 version – 30£ including RS550 motor.
24:1 version – 34£ including RS550 motor.
Please for more information e-mail – info@robotextreme.pt
