Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Fuses for LIPOs on Featherweights
  1. #11
    Maxamuslead's Avatar
    Roboteer
    Status
    Offline
    Name
    Mark-s
    Robots
    "Blacksmith" (FW) under construction
    Location
    Lincolnshire, Threekingham
    Posts
    127
    Post Thanks / Like
    Quote Originally Posted by maddox10 View Post
    The motor is running that axe for 3 events now. But as an axe it ain't very effective. As selfrighter it's great.
    Gearratio is about 25 to 1.
    Mod1 gears just shear off on the secundary and tertiary stages. So those are mod2.
    ahh more of a BB "Bombshell" point scorer axe then damage axe.
  2. #12
    Member
    Status
    Offline
    Name
    Nat
    Robots
    Short Circuit (HW RWs6) DELLapidated bANTtery (AW) LowMoe (AW) Several unnamed ants
    Location
    Eastleigh, Hampshire
    Posts
    117
    Post Thanks / Like
    I am powering a 135 watt brushed motor with axe through a 2stage gearbox and 2 drills
    I have a 30 amp fuse at moment on the drive side just as using electronise esc on drills but the weapon will take the current draw
  3. #13
    maddox10's Avatar
    Member
    Status
    Offline
    Posts
    2,270
    Post Thanks / Like
    Pretty simple then, a 100A fuse from car audio or simular will do nicely. Using an 400A forklift fuse would be very very much overkill.
  4. #14
    Member
    Status
    Offline
    Name
    Nat
    Robots
    Location
    Posts
    117
    Post Thanks / Like
    Thank you for clarifying for me, will get one of those flat fuses not the maxi ones as the screw terminals look a bit more nicer and mount easier.
