This is my first featherweight of three, this one is called Ravil Lamein & it will have a low pressure co2 flipper. The pictures you see is the small parts I had like the base plates & some armour plates I had from college 2008, but I want to weld up the chassis to make sure the armour fit. The steel tubings I got few weeks a go from the B & Q store. Ravil Lamein was going to be a 4 wheel drive flipper but I found on facebook that there few issues with having a 4 wheel drive flipper robot so I'm planning to go stick with 2 wheel drive. The extra slots for the extra will be there to lose extra weight, & the gold markings are line to cut the steel as well as new drive system for the 2 wheel drive Ravil Lamain, I'm going to use 24volt drill motors but I'll get chassis built first. The Ravil Lamein is a cartoon charater version of based on a gothic/punk girl base on a Canadian rock star avril lavien.
the steel base planet
The steel base plate is about 1 - 3mm thick & the black tap is a marking for the steel chassis, golden marking as well as the black making is to show how I planning to lay everything out but it may change plus the there are 4 wheel slots the front 2 may have to be use to lose weight to satrt off.
The chassis
this steel will be used to create the chassis for Ravil Lamein, possible with holes to lose more weight.
I'm planning to build 2 more featherweight robots as subs in case Ravil Lamein fail to work or for my team mates
So what do you all think.
