(I would have put this under commercial adverts, but I'm not allowed to start a new thread in that section for some reason)
The NanoTwo (N2xV) range of speed controllers are single board, dual motor controllers that I have been developing over the last few months specifically to control Antweight robots. They use a pair of integrated motor driver ICs controlled by a PIC microcontroller, and also include a 6 Volt, 1.5 Amp voltage regulator which supplies power to the receiver and drive servos.
There are three variations of the NanoTwo:
NanoTwo Low Voltage (N2LV)
NanoTwo Low Voltage High Power (N2LVHP)
NanoTwo High Voltage (N2HV)
The 'Low Voltage' boards are smaller, but only work with a 2 cell Lipo. The 'High Voltage' board works with 3 and 4 cell Lipos (and a well charged 2 cell).
The two �Low Voltage� boards are the identical except the �High Power� version has two driver chips on each side, effectively doubling the available current output.
For more details, check the datasheet: https://docs.google.com/document/d/19oFbqru5-Iwutio1Mt0i7QXO_RsyPf8I7_5n3YKdTXg/edit?usp=sharing
The full list of options are shown below.
Options:
. Low current (N2LV), High current (N2LVHP),or High voltage (N2HV)
. Onboard signal mixing or no signal mixing.
. Servo connectors on signal input or Rx power or loose wires for soldering
. 6V and signal connections to receiver or signal only.
. JST battery connector or loose wires for soldering.
. Shipping or collection at next AWS
If you have any particular requirements, ask in the email to check if it�s possible.
Prices:
�20 for the N2LV (Low voltage)
�25 for the N2LVHP (Low Voltage High Power)
�25 for the N2HV (High Voltage)
�2 for shipping
Email me or check the datasheet or if you have any questions.
I have a thread on the development of the ESCs at http://robotwars101.org/forum/viewtopic.php?f=1&t=2128
If you would like one, please email your list of options to: rapidrory@gmail.com
I will get back to you to confirm your order, after which you'll need to send the required amount via PayPal to the address above before I can ship it. It'll run on a first come first serve basis, and depends on what components I have in stock/ how much free time I have as to how fast I can ship it. Therefore I can't give a fixed timescale, though I'll try and give an estimate of how long it'll take in the order confirmation.
Alternatively I can take cash in person at the next AWS if you want to collect it there, although you'll still have to email me your options in advance
This is the first time I've done anything like this, so a few things may change around a bit at first, but hopefully nothing too major.
