Page 1 of 10 123 ... LastLast
Results 1 to 10 of 95
Thread: Team Gas Diary's
    Hey guys
    Thought I would post a some what build report / blog on my builds. Decided to go back into this weird hobby as frankly I missed it heeps. Since my last involvement with robots I have mostly been building arcade cabinets and a handheld netbook mame emulator
    Things have changed and I now live in a studio apartment in Wimbledon, London. I have a balcony but next to no space. So lacking my larger tools and room to make a mess.
    So my diary could be helpful for those in similar positions.
    My mentality on robot projects is also going to change. Rather than 'try and build for this event' I am going to take my time. It will be ready when its ready. My past robots have really suffered from rushing and not proper planning.
    I designed the robot in maya which isn't recommended. Its what I use on a day to day basis and didn't want to learn new software. I wanted the robot to have quite a lot of parts to snap together. Advantages is if a part gets damaged I can just print a new piece and cut it out.
    Main chassis is 6mm nylon, backed up with 8mm HDPE and the armor is undecided but Ti or ali is being considered mostly on weight
    47 different robot parts of Nylon
    42 pieces of HDPE
    After I was happy with the design I imported it into illustrator and printed it all out. Initially I tried to print a giant tiled a4 sheets to create 50 by 100cm. After trying to attach the 7th sheet and not happy with the accuracy I had more sense and printed out as many parts that i could fit on a4 sheets and layed them out accordingly. Only the bulkheads needed more then a4 and was an easy task of lining up the prints.
    Cutting wise There were a few tools which were essential
    router for the long straight lines and the bevels on the bulkheads. FIrst time using this and made sure I had lots of practice before working on the nylon. Used G clamps, very large spirit level ruler and took my time
    Rage mitre saw which is more accurate and used as much as possible and can cut up to 220 mm
    Jigsaw which was for the more unacurate cuts but was used occasionally on the small parts
    Dremel Surprisingly very efficient toll in helping the chassis slot in together
    Piller drill for the holes
    The nylon was tricky to cut at times. It got caught on the mitire saw occasional and I had to do very slow cutting on it. Melted a lot when cut with a jigsaw.
    HDPE is awesome to work with. Very soft, like butter in most tools. Was perfect for bridging parts of the chassis together.
    Assembly was straight forward. Surprisingly time consuming. but most is being held by m3 bolts and 3mm screws. Robot looks very ikea. So many parts. Surprisingly everything is very accurate. Really impressed with my handy work. Measurements are only off by 1mm here and there but still very much in range of my CADbulkheads wip2.jpgFirst parts assembled.jpgassembly 1 motor temp fitting.jpgassembly 2 front view.jpgassembly 3 back view.jpgBulkheads wip 1.jpg
    Sorry, I didn't mean to thank your post, my iPods touch screen is a bit glitchy!
    You robot is looking excellent though !
    Thanks Guys! I was a bit baffeled about the like Sam as I didnt do anything ^_^
    Really trying to do my best with this build. As little bodging as possible
    Lazy day at work and I found a video of Trojan II
    Be warned, Dave is very rude at the end :P
    How did you cut everything so straight and square?!
    When I tried to cut my HDPE bulkheads by hand they were about as square and a curly wurly!
  8. #8
    Howdy PJ
    The bulkheads are Nylon and I cut them with a router and a large spirit level ruler (picture related)
    Placed the ruler about 5cm away from the cut (way my router is setup)
    Secured very tightly with heavy duty G clamps (bit of scrap wood to not damage the ruler and the bench)
    Push firm and cut with the router.
    Happy with the results but as expect few MM off here and there without CNC cutting. So I bolted the bulkheads together and filed them down till they were all quite identicle
    Hope that helps
    #edit
    Sorry you quite clearly said everything rather then just the bulkheads
    Big thanks to loads of the straight cuts to my sliding mitre saw. Made life a lot easier and it has a large slide function. But as I said nylon is very scary to cut on it. Have to cut very slowly or it catches rather then cuts.
  9. #9
    Good idea, I tried something similar with a Jigsaw, but didn't work out, Router might work better! Cheers!
  10. #10
    Good to see you back in the game Marco
    Apologies for that video
