Page 14 of 20 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 200
Thread: Team Pasty Build Diary: Loki
  1. #131
    Redesign in the works... seem to have some spare weight at the moment
  2. #132
    It would be fine. If your protective blade gets under them then you are good to flip. Also your blade will probably be stronger than their flipper edge so its less likely to be twisted by spinners and made useless.
  3. #133
    Current design of Ziggy, uhh I mean Loki 2, still playing around with the details.
  4. #134
    Looking good! If you have any spare weight, add a horizontal strip to the back of the wedge at ground height. Even a 20mm strip will make the leading edge far stronger and bend resistant.
  5. #135
    After advice on the motor mounts I've designed, bit restricted for space at the rear end so I've come up with this:
    The top two bolts are m6 80mm, and the bottom is the 14mm aluminium wheel axle, bored 5mm into the 15mm HDPE side and held in place with m6 bolts (don't tell Ellis that I steal all his ideas). Worried it might be a bit vulnerable being attached to the sides?
    Also the mount I've designed in 6mm 'Ecocast' aluminium. Overkill? Adequate?
    Cheers
  6. #136
    Is the axle fixed or rotating? I would move the top screws down as close to the wheel as possible to minimise the effect of flexing in the plastic on the gear mesh. Is the motor mount attached to the base plate or just the sides?
  7. #137
    It's a fixed axle, good idea about moving the screws. As it stands it's only attached to the sides.
  8. #138
    As your in the design stage, I would urge you to move the motors so they're side by side. For you this is easily achievable because of your gearing set up. Reducing the width will reduce your overall size, meaning more wieght for armour. Out if interest what are the overall measurements?
  9. #139
    Max's Avatar
    Member
    Will the wheel have a bronze bush or bearing in it or will it just spin directly on the axle?
  10. #140
    Gabe I have considered side by side motors the only problem is the bottles lie lengthways on either side of the arm so I it needs to be that width to accommodate them anyway and the whole thing would either have to be longer so the motors go behind the ram or alternatively in the spaces where the bottles are now so then would probably have to be taller. Also I've got the motors with gears welded on already lol.
    Max I've got some Oilon to make bushings, do they just reduce friction and wear?
