quote:
I dont enter anything I havent rendered.
Well I guess you cant enter, then.Rules state you need at least one realie.
Never said I wouldnt render a realie. Ive done it before.
http://www.deviantart.com/deviation/31586008/?qo=13&q=by%3Amental-rectangle&qh=sort%3Atime+-in%3Ascrapshttp://www.deviantart.com/deviation/...rectangle&qh=s ort%3Atime+-in%3Ascraps
Unfortunately, this ones in the wrong weight class.
(Message edited by parassyte on April 16, 2007)
Ya got me, but Ill be back!
Okay, Im back. Whats new?![]()
Can I enter? I do not spam anymore and heres one of my robots.
Robot Name:Flippatron
Weight: 99kgs.
Weaponry: a flipper which feeds off 3 36v batteries and 2 co2 canisters which should toss about 100kgs. This is also the srimech
Movement: 2 wheels which is run on 2 darkfusion batteries (I think thats what theyre called) each which should drive at 15mph even though it s top speed is 23mph it cant run for long on 23mph so it must run 15mph.
Team Name: Team Karma
Vapourboteer Name: Tim Sillery
Dimensions: 180X80X210
Shape: A Box like robot.
Ground Clearence: 15mm
Strengths: Can toss any robots, quick and easy to attack.
Weaknesses: Easy to get under, sometimes unreliable.
Timmy, you robot is a flipper and under the flipper is 15mm gc, so it wont get underanything
...hes back.
Okay Tim, some pointers...
1. EIGHT VAPOURBOTS/ROBOTS. EIGHT. Jeez...
2. Some errors with your stats:
Is your flipper front or rear hinged? You dont need batteries for a flkipper, either. Also, 2 CO2 canisters should toss more than 100kgs, I do think...
What are the wheels made of, Vulkalon rubber? Are they based off of a realie? You dont have to babble on about speeds, though: just say its top speed is 23mph and its average speed is 15mph.
Impossible. Unless your robot is made of cardboard. And Ill assume that since you dont give any armour stats.Either shorten the dimensions and get some armour or expect a serious loss. That is, if I allow you to enter that.
Youre going to have a hell of a hard time getting under robots with 15mm all around, as Martyn said. Make the ground clearance shorter, say, 5mm or something, and make the front flippers clearance 0.
Just some friendly vapour advice.![]()
another pointer...
the tournaments full...
Well Martijn, maybe not, because some people *cough*CHRISCALEXMWAJ*cough* dont have bots in at all. =P
People who have all their bots in
Steven McGregor
Christopher Mason
Frank Goacher
David Sheppard
Anthony Politzi
Alex Holt
People who have some bots in
Martijn M Benschop (need one)
Aaron Knight (need one)
Martyn Forsyth (need seven; only has realie =P)
People who dont have any bots in yet
Chris Cooper
Andrew Jackson
Alex MacWilliams
Therefore, Matty, Tim, and Nick, you are welcome to enter 8 robots/vapourbots, and if you do, then youll take a space from either Chris, AJ, or Alex MW.
Okay soz the ground clearence I forgot to say was the back and the sides because the front has a wedge extender to make it 0mm ground clearence. ok if you say so then you say how much 2 CO2 canisters can toss and thats how much it can toss and the flipper is Chaos 2 and Gravitys type of flipper. Dimensions 60X35X80mm and the armour is 5 mm bulletproof plastic ( If there is such thing) If there isnt then 5mm titanium.
Real robots:
Gravity
Wheely Big Cheese
Chaos 2
Pussycat
Bigger Brother
St Agro
Bulldog Breed 3.
More flaming to do...
No, no, NO. Youre the one whos supposed to come up with a reasonable value, and if you cant do that then you shouldnt partake in these things.
Again, youre making unrealistic values, Tim. You need to do research before you ever try making robots. Buy some robot books or find some good sites, PLEASE. Otherwise dont come here.
Im not accepting your entry until you do some major improvements.
