Results 1 to 8 of 8
Thread: Pnumatics help
    Guest
    ok ive got 2 rams (thanks simon)and a small air tank what else do i need all help is appreciated
    what sort of air tank, fire ext or buffer (low pressure)? you will need; Valve (maybe two, help speed it up), regulator, 1000psi pressure relief valve, LP pressure relief valve, HP pipe and LP pipe plus fitting. This is assuming your using co2. visit; http://www.blazerbotics.co.ukwww.blazerbotics.co.uk theres a pneutmatics bit in the technical section, with links to other sites.
    Guest
    thanks its a paint ball tank
    either you got msn?
    http://www.teamdavinci.com/understanding_pneumatics.htmhttp://www.teamdavinci.com/understanding_pneumatics.htm
    Guest
    no msn sorry but my team mate has its smelvin296@aol.com but his computer has gone in for repair
