I know I can speed hack the SD150 servo but is it best to join the purple and pink gears or the two blue ones.
http://www.freewebs.com/anticide/gear%20set.bmphttp://www.freewebs.com/anticide/gear%20set.bmp
take out the light blue one glue the two together that sit on top of each other
Andrew its 6 of one half a dozen of the other. WHich ever you want really.
I have replaced the light blue one and the speed hack is great. Proberly a bit slower than the NARO running at the same voltage but i am using bigger wheels.
I am building a crusher, so most the weight is out of the way at the back so the bot goes all the way onto its back, with the slightest touch of the stick. I may have to steal marcos idea of the brass strip at the back for support.
