Results 1 to 8 of 8
Thread: Batteries
    cruncher
    Guest
    HI
    WHO SELLS ANTWEIGHT BOT PACKS SAY A PACK OF 2/3 BATTERIES!? (LIKE REBELS)
    CHEERS
    JONO
    http://www.overlander.co.ukwww.overlander.co.uk
    or
    http://www.indoor.flyer.co.ukwww.indoor.flyer.co.uk lithium batteries
    Guest
    If you look to the left of your A key, there is a key labelled, Caps lock. Press it, and a little light will go off on the right hand side of the keyboard. You can then post without pi**ing people off.
    Does anyone know if some 9gram servos similar to the HS-50s will take a 9volt Alkaline pack behind them?
    Guest
    They probably will, but for how long?
    No Ive always blown my HS-50 servos up on 8+ volts
    Guest
    You learn something new every day!
  8. #8
    Okay, so you reckon 6v is a much safer voltage? Is there a way to speed mod the HS-50s and how much RPM does it have on 4.8v?
