Page 14 of 14 FirstFirst ... 4121314
Results 131 to 135 of 135
Thread: Mute
  1. #131
    team_mute's Avatar
    Member
    Status
    Offline
    Robots
    Mute & Bonk
    Location
    Stoke-on-Trent
    Posts
    179
    Erm they are not really gear boxes, we mount one gear on the wheel and one on the motor and run the wheel on a fixed shaft.
    We got the gears from HPC Gears, but I've seen Technobots do gears as well.
  2. #132
    team_mute's Avatar
    Member
    Status
    Offline
    Robots
    Mute & Bonk
    Location
    Stoke-on-Trent
    Posts
    179
    Bonk is ready for the weekend, we've added a new point head, we did a quick test as the video below shows and got a bit of bend on 3mm hardox. Got to test out the new drive wheels and rear omni wheels to see if it will drive and if we can manage to hit anything
  3. #133
    Member
    Status
    Offline
    Name
    playzooki
    Robots
    AW - Jaguar (in progress)
    Location
    yorkshire
    Posts
    179
    Wow
  4. #134
    kodster's Avatar
    Member
    Status
    Offline
    Name
    Kody Kunz
    Robots
    Coming soon...
    Location
    Etobicoke, Canada
    Posts
    6,643
    Dayum. That's quite the powerful axe, guys. You definitely thought this one out. Well done.
  5. #135
    team_mute's Avatar
    Member
    Status
    Offline
    Robots
    Mute & Bonk
    Location
    Stoke-on-Trent
    Posts
    179
    Cheers, Bonk's 1st and only fight at Whitwick this weekend, we managed to chop Titan's axe head off but lost drive after the impact with Tanto, a plate came loose and jammed the drive gears. Seems the valves need a remachine to allow for the cooling of quick firing.
    Currently just adding some new bits to the front to stop the motor jamming.
