Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 81
Thread: FW- Crash Course
  1. #71
  2. #72
    Just to add, my robot was on the compact side and had a bit or hardox armour so thats why its so small.
  3. #73
  4. #74
    Ocracoke's Avatar
    Team Kaizen
    5mm HDPE over the top isn't going to be enough. Azriel, with the new axe on it, will go through that. Similarly the aluminium, it might be OK for a bit but it'll twist if it isn't supported and if a spinner catches it, it'll rip.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
  5. #75
  6. #76
    Ocracoke's Avatar
    Team Kaizen
    The Honey Badger 2.0 ran with 10mm HDPE with a aluminium front at its last incarnation. Even though that was screwed to the front, it did fail after one or two fights I seem to recall.
    Generally, the thicker you can get it, the better, especially when in full combat with spinners, weight permitting of course. The 10mm HDPE did "fine" for the most part but there is a reason why Azriel uses 15mm on all sides. :P
    FW: Azriel
    MW: Jibril, Kaizen
  7. #77
  8. #78
    Ocracoke's Avatar
    Team Kaizen
    Could fit a brushless motor to the actuator like Aegis did, that works very nicely.
    FW: Azriel
    MW: Jibril, Kaizen
  9. #79
  10. #80
    Ocracoke's Avatar
    Team Kaizen
    Indeed, it is somewhere on the forum, I think possibly in the build thread.
    FW: Azriel
    MW: Jibril, Kaizen
Tags for this Thread
