Results 1 to 7 of 7
Thread: Jerry Can - Featherweight 1st Build
    Ocracoke's Avatar
    Team Kaizen
    I need an ESC, wheels to get me started and progress to tank tracks when I've got it all working. I need the materials to mount all the gear to, as a base. I'm hoping for inspiration as I go along, with a degree of flexibility in the design along the way.
    So if you wanted a ESC, I could recommend trying out a pair of BotBitz controllers (https://ranglebox.com/shop/product/b...a-brushed-esc/ for example) as they are pretty reliable in my experience and can handle the nominal voltage of the drills you mention. Base, can't go wrong with something like a 10mm HDPE base panel. Easy to machine and work on.
    I like the idea of a Jerry Can, very mechanical feel to it. What I should note is that, like Bread Dead Redemption, the metal is going to be fairly thin and I guess would easily buckle under the inertia of some of the robots on the scene. You probably want to wall around the bottom bit with some more HDPE (15mm maybe) so the main can itself isn't reachable.
    Tracks are rare in the FW class, Aegis is the only one that springs to my mind of being a tracked robot (and I not sure if that is correct either). I might suggest basing it on a chain with some low shore rubber treads for extra traction. It'll definitely be unique on the scene.
    BW: Shu!, The Honey Badger
    Sounds great! Is going to be very distinctive to look at but you've also got a nice big box shape to fit everything in. Look forward to seeing it take shape! Do you have any concept sketches?
    I also like this idea and as I said to Andrew during his Bread dead toaster build-More like this please!
    I found myself eyeing up a exhaust silencer box a few weeks back with the intention of turning it into a
    featherweight but I'm now busy with a heavyweight rebuild as a priority.
    Hope your concept comes to fruition Roger as so many never do.
