Results 1 to 8 of 8
Thread: Gunblade Build Diary - FW spinner
    Ocracoke's Avatar
    Team Kaizen
    Is a chain drive or belt drive better for a featherweight horizontal? I've seen chain drive on some American robots.
    Belt. Easily, it'll slip on excessive torque and not snap like a chain might I'd imagine.
    BW: Shu!, The Honey Badger
    My understanding from other people's spinners is that you have to have some give in the system, so if you use a non-flexible drive from the motor to the spinner (chains or gears) you have to include a clutch/torque limiter somewhere or you risk destroying your motor or transmission. So a belt isn't essential but it seems much easier!
    Edit: Also, good luck!
    Ocracoke's Avatar
    Team Kaizen
    Looks neat. How do you add the grub screws to the wheels though? Do you cut a circle of HDPE and then lathe down to create a hub as part of the wheel so that you can drill that for the screw?
    Ocracoke's Avatar
    Team Kaizen
    I'd recommend that.
Tags for this Thread
