Results 1 to 8 of 8
Thread: Featherweight Nelly rebuild.
    Ocracoke's Avatar
    Team Kaizen
    Neat. Certainly looks like a robust shell. Looks like just the shell parts, what do you plan to put back into it?
    AW: Amai, Ikari, Osu, Ramu
    BW: Shu!, The Honey Badger
    I like it !
    All Robots should have a face,it gives them character.
    I think back to the Robot Wars days and some Robots Didn't do well but you
    can still remember their Faces like Diotor,Milly anne Bug and errr struggling a bit now Death warmed UP....Who? oh forget it
    HDPE can be worked with normal wood working tools, for straight lines I’m currently using a standard wood saw (a hacksaw can make neater cuts), for the wiggly bits I have a jigsaw with wood blades, cutting a straight line takes practice though! Maybe you could clamp a straight edge to the piece and follow it as a guide? For reference I’m currently using a combination of 18 and 25mm cut from pipes.
    Team Pushover - Definitely worse at this than you are!
    AW - Pullover (Grabber), Wej (er, wedge), Ridic-U-Loch-Ness Monster (Secret)
    BW- Leopold (On Hold)
    FW- Pushover (well, half of it...)
    Ocracoke's Avatar
    Team Kaizen
    There is this guide to working with the stuff which is quite detailed: https://www.fightingrobots.co.uk/thr...work-with-hdpe
