Results 1 to 4 of 4
Thread: Electric Hammer/axe
    Can anyone post pictures of the internal weapon layout for an electric hammer/axe?
    Roboteernat's Avatar
    Roboteer
    Status
    Offline
    Name
    Nat
    Robots
    Location
    Eastleigh, Hampshire
    Posts
    313
    is my test of my mech, will find some pics too
    Mine is a 2 stage chain running to about 6:1.
    Sadly this was due to space constraints with the shape of the robot.
    Motor
    9:14
    36:9
    AXE>>>>>>>>
    will confirm soon
    RogueTwoRobots's Avatar
    Roboteer
    Status
    Offline
    Name
    Jamie McHarg
    Robots
    Location
    Aberdeen, Scotland
    Posts
    3,962
    Later swapped out the drill motor for a scooter motor but the layout remained pretty much the same.
    Axe arm bolted on to the large sprocket, ran on a speed controller and I just pulsed it to control the swing and not over-swing/hit the chassis.
    Jamie McHarg
    RogueTwo Robots
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Somewhere on the Wirral
    Posts
    1,005
    Ampflow F30-150 connected to a MOD 1.25 20T pinion gear, going to a 70T and then a 20T to a 90T final output gear which the Scythe axe is bolted to. This results in a 15.75:1 ratio. This setup isn't ideal as it has little shock resistance. A chain drive like Jamie and Nat's have as a final 3rd stage reduction would be preferable.
