Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: BotFest 3 (14th September 2019)
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Somewhere on the Wirral
    Posts
    980
    Hey Everyone!
    It is time for our third BotFest event! This time, we are trying out a new venue, this being:
    The Belvidere Centre
    Belvidere Rd,
    Wallasey
    CH45 4RY
    Date: 14th September 2019
    Time: 10:00 - 17:00 (ish)
    Like last time, we'll be running a set of 4 heats, quarter finals, semi finals and a grand final. We'll also be having a all robot rumble at the end and if folks want to organise a whiteboard or side-event in the intermission, please feel free to do so. The arena will be getting a new floor to replace the old floor that was in there so no more getting caught on the join.
    As always, this is an Antweight event (I know there was mention of this being a Beetleweight event but I've not had the time to get an arena built) but if you wish to do a static display your heavier class robots, please feel free to bring them with cradles and sharps protection where needed. As before, we are running a slightly modified variant of the AWS ruleset (http://robotwars101.org/ants/rules.htm), those being:
    2.a: Weight limits have a 5% variance, so the maximum permitted weight for a Antweight roller is 157.5g and for a Antweight walker is 236.25g. Robots that exceed the AWS weight limit but are within the variance will have a note applied to the technical check sheet but pass in this instance.
    2.b: Size limits have a 5% variance, so the maximum size for a particular dimension for a Antweight is 106.68mm. Robots that exceed the AWS size limit but are within variance will have a note applied to the technical check sheet but pass in this instance.
    4.a: Heat matches will last 2 minutes. All other matches (except the All Robot Rumble and Side events) will last 3 minutes. The All Robot Rumble will last until one robot remains mobile. Side event runtime are determined on the day.
    5.g A team is permitted to enter up to 3 robots of either a roller or walker.
    Event signup is here: http://antlog.garya.org.uk/event/22
    Hope to see you there!
    James Williams's Avatar
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Neophyte, Meteorite & Exabyte (FW)
    Location
    Birmingham
    Posts
    99
    Great to see, was worried this might clash with the AWS. Looking forward to it.
    James
    Team Phyte
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Posts
    980
    Indeed, is AWS 59 definitely running on the 21st of September? I didn't want to clash with it.
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Location
    Birmingham
    Posts
    99
    The plan is the 21st but since they're still finalizing the details I suppose it's not 100% certain yet. It's also being held in Sheffield so it would be particularly harsh for the notherners if they had to choose between two of the few events they get up there.
    James
    Team Phyte
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Posts
    980
    Ah, OK. Hmm... If AWS does land on the 14th (I get the feeling it won't from what I have heard), I am sure I can make alternative arrangements. For the moment, treat it as if it is still the 14th for the time being and we'll see where it lands.
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Posts
    980
    Excellent, AWS 59 is on the 21st of September, our date of the 14th stands.
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Location
    Birmingham
    Posts
    99
    Phew, crisis over, I thought I'd started something there.
    James
    Team Phyte
    Scarrosaki's Avatar
    Roboteer
    Status
    Offline
    Name
    Jon A
    Robots
    Bodacious Fyraan-Gaaris (AW), 2 Bodacious 2 Spurious (AW), Thunderpants (BW), RCS (FW thwacker)
    Location
    Chester UK
    Posts
    22
    Looking forwards to it
    Bad Wolf's Avatar
    Roboteer
    Status
    Offline
    Name
    Bad Wolf
    Location
    North Wales
    Posts
    96
    Ill be there! Can't Wait!
    Bad Wolf
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    83
    This sounds really good! Will try and come to this even if dont have a running robot if thats ok just to see and learn from you guys
