Page 30 of 30 FirstFirst ... 20282930
Results 291 to 299 of 299
  1. #291
    Ocracoke's Avatar
    Team Kaizen
    Yeah, wasn't immediately keen on the handheld face shield, much rather have something that allows me to handle the welder properly. Thanks for the heads up, will see if I am brave enough to give it a go when the weather clears up!
    BW: Shu!, The Honey Badger
  2. #292
    Ocracoke's Avatar
    Team Kaizen
    Jibril
    Work has happened. Very descriptive, I know :P The chassis has been modified a little to allow the axe motor and carrier to come out in one piece. The U bolt holding the back of the motor in has been installed and just needs cutting to size. Currently in the process of getting the lids bolted down.
    I also adapted the carrier to bolt into the main chassis when installed so that it won't go anywhere. The rear armour plates have been test located and fit, just. I've also, finally, had news on the Scythe and the front wedge plate which *finally* means I can crack on and get this robot finished. The Scythe attachment is going to be a fiddly job, needing my first ever countersinking job and some stubby M10 bolts, preferably in Titanium. It'll make sense when you see it.
    I am aiming to have this done by the end of March to give enough time for stress testing before events hopefully restart. Of course, video footage to come soon.
  3. #293
    Ocracoke's Avatar
    Team Kaizen
    Jibril
    Some more work happened and... well... here it is.
    That is... wow for me. It obviously isn't quite finished yet but at the moment, minus the Scythe-Axe, it could go into the arena as is. I'd like to think it is much better engineered than the last version, time will tell if it is when it does eventually get into a fight. Weighing it all, it comes in at 38kg which is silly light. I might be able to fit thicker side arms and add some headweights to the axe for the lethal hit.
    At the moment, the gearbox for the carrier has been disassembled as the Titanium shafts need keyways cutting and I'll sort out the drilling of the gears to attach the Scythe-Axe to the gear if only to get the experience of doing countersink drilling.
  4. #294
    Looks fantastic Lucy! Congrats on getting it finished, hope it gets to run very soon!
  5. #295
    Looking forward to fighting Jibril with my heavyweight
  6. #296
    Ocracoke's Avatar
    Team Kaizen
    Its certainly pretty much all together now, just needs the machine work doing to the shafts and paint, obviously. :P
    Oh yes, I am looking forwards to fighting with your heavyweight too!
  7. #297
    Ocracoke's Avatar
    Team Kaizen
    Things have been happening. They happen in the universe but specifically, things here :P
    Jibril
    I've test ran the robot with the side arms and yes, they do scrape but not enough for them to really be an issue. The robot moves happily with them on so I think leaving them "as-is" is the best way forwards for the moment. Really speaking, all the robot needs now is paint, final assembly and sorting out the Victor BB as it seems to not want to co-operate when powered on for the first time.
    As far as the Scythe-Axe goes, I've had the parts machined now with a keyway (so many thanks Nat!) and they are on their way back to me as I write this. I need to order the key steel but I am finally looking forwards to having this robot done and tested. I do, however, need to get some headweights ordered for the Scythe, it isn't as heavy as I first imagined but that is definitely a "later" job.
    The Honey Badger
    I've been accepted into the Rapture event in July so this presents a big chance for me to do some work on this one. One of the biggest bugbears I have with the current 4.0 version is the lack of any active weaponry on it. I could fit an axe to the existing robot but at this weight class, an axe isn't very effective. I therefore elected to experiment a little with some left over 3mm PVC from Shu! 1.0, a test motor and some 4mm polycarbonate I had laying around to make this:
    Despite it being somewhat hacked together (this was done in about in hour) it mechanically works and will form the basis of a front hinge arm on The Honey Badger 4.1.
    I've ordered some new HDPE to rebuild the shell entirely and the arm is going to use the motor from Shu! 2.0 to power it since that is a straight swap and Shu 3.0 is probably moving to a different weight class. The MFA motors from the 4.0 version are going into the 4.1 version along with their speed controllers but a new wiring loom is needed, the one in there is fairly rotten and definitely needs replacing.
    The whole machine is going to shrink slightly as it needs to fit within a 250mm square area. but honestly, with a bit of clever imagination as to placement of parts, it won't be an issue.
  8. #298
    Ocracoke's Avatar
    Team Kaizen
    Key steel has arrived today. Made a slight miscalculation in the sizes I ordered but I've got the right sizes as part of the order so in theory, there is very little stopping me rebuilding the gearbox now. I want to get the Scythe at least painted and fitted onto the gear before doing so though.
    Countersinking bits and titanum M10 bolts are on order but I need to get a new pillar drill and corded drill as well so I don't expect anything to happen with Jibril until the end of the month at the earliest.
  9. #299
    Ocracoke's Avatar
    Team Kaizen
    The Honey Badger
    After a few evenings and weekends working on this, I am happy to show off The Honey Badger 4.1.
    Weighing in at 1.42kg with an electric front hinged flipping arm, I am quite pleased with how this has come out. Its relatively quick and should hold up to some pounding this time. Not that the last one didn't but this is a refinement of what was already there. A new wiring loom went in, the flipping arm mechanism is pretty neat (by my standards anyway) and it is nice just to have a robotics project finish and finish well on time for some testing before attending an event.
    And yes, this one definitely self rights
    The only couple of relatively minor things I want to get done on this now is some metal edging along the top and machining the front slightly to run flatter on the front.
    Jibril
    I'll save the big reveal for a couple of weeks time for this but I'll reveal that armour plating has been painted and the Scythe-Axe gearbox has been assembled. Barring a few little pieces needing finishing, this is also nearing completion.
